BMW Standard Tools 2.12
Posté : 30 janv. 2013 14:41
Nouvelle version est sortie, avec cette fois NCSExpert qui fonctionne sur Windows x64. Bonne nouvelle donc.
Release Notes for BMW Standard Tools
Copyright © by BMW Group
Tool-Setup Version 2.12.0 - 11.10.2012
Support: Flash Service
The following programs will be installed or updated:
Program Default directory Description
EDIABAS C:\EDIABAS Vehicle diagnostic tool
WINKFP C:\EC-Apps\NFS Vehicle programming tool
NFS C:\EC-Apps\NFS Control tool for winkfp
INPA C:\EC-Apps\INPA Vehicle diagnostic tool
NcsExpert C:\NcsExper Vehicle coding tool
Program File-Versions Package
EDIABAS: 7.3.0 1.1
-Tool32 4.0.3
-CANdriver 2.5.0.0
WINKFP 5.3.1
- CoAPI 3.13.2
NFS 5.2.9
- KMM SRV 4.31.1.0
INPA 5.0.6
NCS Expert 4.0.1
Setup Version History:
BMW Vehicle programming
Toolkette-Setup Version 2.12.0
Changes and extensions Toolsetup of 2.11.0 to 2.12.0
Changes:
Integration Ediabas 7.3.0 Package 1.1
Integration WinKFP-Tool 5.3.1 with CoAPI 3.13.2
Integration NCS-Expertentool 4.0.1 with CoAPI 3.13.2
Changes and extensions Toolsetup of 2.10.0 to 2.11.0
Changes:
Installation under Windows 7 32 Bit released
Integration Ediabas 7.2.0 Package 2.3
Integration NFS 5.2.9
Integration WinKfp-Tool 5.2.3 with CoAPI 3.12.4
Integration INPA 5.0.6
Changes and extensions Toolsetup of 2.9.0 to 2.10.0
Changes:
Installation under Windows 7 possible but not further supported
Integration Ediabas 7.2.0 Package 2.0
Integration NFS 5.2.0 mit WinKfp-Tool 5.2.1
Integration Vector CAN Anbindungstreiber 2.5.0.0
Changes and extensions Toolsetup of 2.8.0 to 2.9.0
Changes:
DLE2 removed, because this component is now fixed part of the CoAPI 3.12.0.
Changes and extensions Toolsetup of 2.7.0 to 2.8.0
Changes:
DLE2 1.0.01, changed for using multiprocessing.
CoAPI 3.11.01, changed for correct behaviour in the context of corrupted PABD(s).
Changes and extensions Toolsetup of 2.6.0 to 2.7.0
Notice:
NcsExpert is again a part of this installation, cause EDIABAS 7.1.0
already supports the 16bit interface.
Changes:
Integration NFS 4.9.1.0
- KMM SRV 4.26.0.0
Integration WinKFP-Tool 5.1.8
- CoAPI 3.11.0
- DLE 2 1.0.0 (für CIC-Rüko)
Integration EDIABAS 7.1.0.500
-Tool32 3.6.1.0
-CANdriver 2.3.0.0
Changes and extensions Toolsetup of 2.5.2 to 2.6.0
Changes:
Integration WinKFP-Tool 5.1.8 including now HDD-Update.
Changes and extensions Toolsetup of 2.4.0 to 2.5.2
Notice:
NcsExpert is not a part of this installation, cause EDIABAS 7.0.0 does
not support the 16bit interface anymore, which is used by NcsExpert.
Please use Toolsetup V 2.4.0 to install NcsExpert as well EDIABAS 6.4.7.
EDIABAS 6.4.7 can be installed into a separate directory. Switching between
the EDIABAS versions can be accomplished by changing the Windows
environment variable PATH via the control panel and using the system dialog.
Changes:
Integration EDIABAS 7.0.0.0 ( P1.7 )
Integration Vector-CAN EDIABAS Interface Anbindungstreiber 2.3.0
Integration NFS 4.8.0.4 with KMM SRV 4.21.0.0
Integration WinKFP-Tool 5.1.6
Support of Interfaces ADS,KBUS und ADS4MOST is discontinued
Support of Interface ENET
WinKFPtool:
- WDP Import with SWT-Dateien
- Integration 7000-er error messages
- Multiinstanz startup behavoiour (new <5 Sec.)
- Processing of UNIX files repaired
- Change of the „Read Calibration values“ function
- So called „BIOS-Timer“ functionality available“
- Bugfix: WDP-Import CA 2006012
- Bugfix: cabi.err support of multiprocess
- Integration error code interpreter 1. step
- Error code data paths extended to 32 Bit
EDIABAS:
- Support of 16 Bit interfaces discontinued
- Support of ADS discontinued
- Vector-CAN connection interface installed via CAN setup
- see also .\EDIABAS\DOKU\englisch\Release.pdf
Changes and extensions Toolsetup of 2.2.0 to 2.3.0
New:
..\EDIABAS\Hardware\OBD\USB OBD.pdf added for user info.
Changes:
..\EDIABAS\Bin\B2BMW.LIB exchanged by new version: 2.20
..\NFS\DATA\GDATEN\SGIDC.as2; SGIDD.as2 and Info.ger update.
..\NCSEXPER\BIN\CABICOMP.EXE removes
Changes and updates from WinKfp 4.6.2 to 5.1.0
New:
- Coapi Work Directory (, DATA,.. etc. cfgdat.) can be configured by a call to “coapiSetSearchPath(...)”
- Bilingual GUI (German/English)
Changes:
- Modification note in “kfconf10.da2, hwnr.da2 and <sgfam.dat>” when importing a WDP
- Bugfix of a textual error at FgNr input in comfort modus
- Change of the WDP import dialog if no file conflict is detected.
Extensions:
- Complete reference check at BSU, Prog.-Prog., Data-Prog., however without reference check before a data programming, because some ECUs do not update their reference without a reset after a program programming. Therefore the reference check fails in this case.
Changes and extensions from CoAPI 3.7.0 to 3.9.0
New:
- With the new function “coapiSetSearchPath()” in the module “coapi.cpp” it is possible at any time to change the data search paths at runtime. Interface functions: coapiSetSearchPath (); coapiGetSearchPath()
- The function fileread() can now be called in a PABD (Bugfix)
- Bilingual CoAPI text output (German/English)
- Modification note in “kfconf10.da2, hwnr.da2 and <sgfam.dat>” when importing a WDP. Interface function: coapiKfSetApplName()
Changes:
- Function for reading VIN, reading ZCS, reading/writing FA changed from using SGFAM to SGET mechanism to determine the correct SGBD file
- Increased the number of max CBDn.
- Increased the maximum entries per line in the *.HWH history files of a WDPs to 199 entries.
Extensions:
- Complete reference check with the Flash programming of program and data with consideration of a possible boot sector update (BSU). Interface functions: CoapiKfCheckReferenzD2(); coapiKfCheckReferenzFromBRIF
EDIABAS: 7.3.0 1.1
-Tool32 4.0.3
-CANdriver 2.5.0.0
WINKFP 5.3.1
- CoAPI 3.13.2
NFS 5.2.9
- KMM SRV 4.31.1.0
INPA 5.0.6
NCS Expert 4.0.1
Changes:
Changes:
Changes:
Changes:
Changes:
Notice:
Changes:
- KMM SRV 4.26.0.0
- CoAPI 3.11.0
-Tool32 3.6.1.0
-CANdriver 2.3.0.0
Changes:
Notice:
Changes:
WinKFPtool:
EDIABAS:
New:
Changes:
New:
Changes:
Extensions:
New:
Changes:
Extensions:
