BMW Standard Tools 2.12
- 540i
- Véhicule : (e39) 540i
Nouvelle version est sortie, avec cette fois NCSExpert qui fonctionne sur Windows x64. Bonne nouvelle donc.
Release Notes for BMW Standard Tools
Copyright © by BMW Group
Tool-Setup Version 2.12.0 - 11.10.2012
Support: Flash Service
The following programs will be installed or updated:
Program Default directory Description
EDIABAS C:\EDIABAS Vehicle diagnostic tool
WINKFP C:\EC-Apps\NFS Vehicle programming tool
NFS C:\EC-Apps\NFS Control tool for winkfp
INPA C:\EC-Apps\INPA Vehicle diagnostic tool
NcsExpert C:\NcsExper Vehicle coding tool
Program File-Versions Package
EDIABAS: 7.3.0 1.1
-Tool32 4.0.3
-CANdriver 2.5.0.0
WINKFP 5.3.1
- CoAPI 3.13.2
NFS 5.2.9
- KMM SRV 4.31.1.0
INPA 5.0.6
NCS Expert 4.0.1
Setup Version History:
BMW Vehicle programming
Toolkette-Setup Version 2.12.0
Changes and extensions Toolsetup of 2.11.0 to 2.12.0
Changes:
Integration Ediabas 7.3.0 Package 1.1
Integration WinKFP-Tool 5.3.1 with CoAPI 3.13.2
Integration NCS-Expertentool 4.0.1 with CoAPI 3.13.2
Changes and extensions Toolsetup of 2.10.0 to 2.11.0
Changes:
Installation under Windows 7 32 Bit released
Integration Ediabas 7.2.0 Package 2.3
Integration NFS 5.2.9
Integration WinKfp-Tool 5.2.3 with CoAPI 3.12.4
Integration INPA 5.0.6
Changes and extensions Toolsetup of 2.9.0 to 2.10.0
Changes:
Installation under Windows 7 possible but not further supported
Integration Ediabas 7.2.0 Package 2.0
Integration NFS 5.2.0 mit WinKfp-Tool 5.2.1
Integration Vector CAN Anbindungstreiber 2.5.0.0
Changes and extensions Toolsetup of 2.8.0 to 2.9.0
Changes:
DLE2 removed, because this component is now fixed part of the CoAPI 3.12.0.
Changes and extensions Toolsetup of 2.7.0 to 2.8.0
Changes:
DLE2 1.0.01, changed for using multiprocessing.
CoAPI 3.11.01, changed for correct behaviour in the context of corrupted PABD(s).
Changes and extensions Toolsetup of 2.6.0 to 2.7.0
Notice:
NcsExpert is again a part of this installation, cause EDIABAS 7.1.0
already supports the 16bit interface.
Changes:
Integration NFS 4.9.1.0
- KMM SRV 4.26.0.0
Integration WinKFP-Tool 5.1.8
- CoAPI 3.11.0
- DLE 2 1.0.0 (für CIC-Rüko)
Integration EDIABAS 7.1.0.500
-Tool32 3.6.1.0
-CANdriver 2.3.0.0
Changes and extensions Toolsetup of 2.5.2 to 2.6.0
Changes:
Integration WinKFP-Tool 5.1.8 including now HDD-Update.
Changes and extensions Toolsetup of 2.4.0 to 2.5.2
Notice:
NcsExpert is not a part of this installation, cause EDIABAS 7.0.0 does
not support the 16bit interface anymore, which is used by NcsExpert.
Please use Toolsetup V 2.4.0 to install NcsExpert as well EDIABAS 6.4.7.
EDIABAS 6.4.7 can be installed into a separate directory. Switching between
the EDIABAS versions can be accomplished by changing the Windows
environment variable PATH via the control panel and using the system dialog.
Changes:
Integration EDIABAS 7.0.0.0 ( P1.7 )
Integration Vector-CAN EDIABAS Interface Anbindungstreiber 2.3.0
Integration NFS 4.8.0.4 with KMM SRV 4.21.0.0
Integration WinKFP-Tool 5.1.6
Support of Interfaces ADS,KBUS und ADS4MOST is discontinued
Support of Interface ENET
WinKFPtool:
- WDP Import with SWT-Dateien
- Integration 7000-er error messages
- Multiinstanz startup behavoiour (new <5 Sec.)
- Processing of UNIX files repaired
- Change of the „Read Calibration values“ function
- So called „BIOS-Timer“ functionality available“
- Bugfix: WDP-Import CA 2006012
- Bugfix: cabi.err support of multiprocess
- Integration error code interpreter 1. step
- Error code data paths extended to 32 Bit
EDIABAS:
- Support of 16 Bit interfaces discontinued
- Support of ADS discontinued
- Vector-CAN connection interface installed via CAN setup
- see also .\EDIABAS\DOKU\englisch\Release.pdf
Changes and extensions Toolsetup of 2.2.0 to 2.3.0
New:
..\EDIABAS\Hardware\OBD\USB OBD.pdf added for user info.
Changes:
..\EDIABAS\Bin\B2BMW.LIB exchanged by new version: 2.20
..\NFS\DATA\GDATEN\SGIDC.as2; SGIDD.as2 and Info.ger update.
..\NCSEXPER\BIN\CABICOMP.EXE removes
Changes and updates from WinKfp 4.6.2 to 5.1.0
New:
- Coapi Work Directory (, DATA,.. etc. cfgdat.) can be configured by a call to “coapiSetSearchPath(...)”
- Bilingual GUI (German/English)
Changes:
- Modification note in “kfconf10.da2, hwnr.da2 and <sgfam.dat>” when importing a WDP
- Bugfix of a textual error at FgNr input in comfort modus
- Change of the WDP import dialog if no file conflict is detected.
Extensions:
- Complete reference check at BSU, Prog.-Prog., Data-Prog., however without reference check before a data programming, because some ECUs do not update their reference without a reset after a program programming. Therefore the reference check fails in this case.
Changes and extensions from CoAPI 3.7.0 to 3.9.0
New:
- With the new function “coapiSetSearchPath()” in the module “coapi.cpp” it is possible at any time to change the data search paths at runtime. Interface functions: coapiSetSearchPath (); coapiGetSearchPath()
- The function fileread() can now be called in a PABD (Bugfix)
- Bilingual CoAPI text output (German/English)
- Modification note in “kfconf10.da2, hwnr.da2 and <sgfam.dat>” when importing a WDP. Interface function: coapiKfSetApplName()
Changes:
- Function for reading VIN, reading ZCS, reading/writing FA changed from using SGFAM to SGET mechanism to determine the correct SGBD file
- Increased the number of max CBDn.
- Increased the maximum entries per line in the *.HWH history files of a WDPs to 199 entries.
Extensions:
- Complete reference check with the Flash programming of program and data with consideration of a possible boot sector update (BSU). Interface functions: CoapiKfCheckReferenzD2(); coapiKfCheckReferenzFromBRIF
EDIABAS: 7.3.0 1.1
-Tool32 4.0.3
-CANdriver 2.5.0.0
WINKFP 5.3.1
- CoAPI 3.13.2
NFS 5.2.9
- KMM SRV 4.31.1.0
INPA 5.0.6
NCS Expert 4.0.1
Changes:
Changes:
Changes:
Changes:
Changes:
Notice:
Changes:
- KMM SRV 4.26.0.0
- CoAPI 3.11.0
-Tool32 3.6.1.0
-CANdriver 2.3.0.0
Changes:
Notice:
Changes:
WinKFPtool:
EDIABAS:
New:
Changes:
New:
Changes:
Extensions:
New:
Changes:
Extensions:
- luce46M57
- Véhicule : 330d e46, 530d e61 2005
Re: BMW Standard Tools 2.12
Bonne nouvelle !
As tu un lien pour partage ?
Merci d'avance
Bonne nouvelle !
Merci d'avance
Très bonne nouvelle ! Merci !
Pourrais tu me dire ou je peux me le procurer ?
- dolu-57
- Véhicule : BMW (E90) 330da
ç'est bon ça!!!
- Véhicule : Bmw (E60) 525d
Le mots de passe à changé pour NCS Expert 4.0.1 quelqu'un le connait?
- dolu-57
julgro a écrit :Le mots de passe à changé pour NCS Expert 4.0.1 quelqu'un le connait?
il te faut un "crack" ou un "patch"... tu trouveras sur un forum bmw anglophone
dolu-57 a écrit :julgro a écrit :Le mots de passe à changé pour NCS Expert 4.0.1 quelqu'un le connait?
Merci à toi j'ai trouvé mon bonheur ;) si il y a du monde intéressé PM
- dolu-57
julgro a écrit :dolu-57 a écrit :julgro a écrit :Le mots de passe à changé pour NCS Expert 4.0.1 quelqu'un le connait?
tu as trouvé les profiles tout prêts où un "patch" ?
moi j'ai les profiles tout prêts, j'ai pas vraiment chercher plus, mais si tu as un patch je suis preneur...
- scandaleur
- Véhicule : E60 525DA excelis
bonjour, auriez vous un lien ou on peut télécharger bst 2.12?
car j'ai deja la version précédente mais comme tous le monde fonctionne a moitié sur windows 7
Salut a tous, moi j'ai telechargé et installé tout ca hier soir mais depuis je suis bloqué.
Je n'ai installé aucun crack ni aucun patch je savai pas qu'il en fallait et en ayant lu ce topic j'en ai cherché mais rien trouvé.
J'ai quand meme essayé d'utiliser NCS expert mais lorsque je selectione le modele de voiture, voici ce que m'affiche le logiciel :
Est-ce du au fait que je n'ai ni patch ni profil telechargé?
Si quelu'un a deja eu ce soucis comment l'a-t-il résolu?
Merci d'avance pour votre aide car la je suis a deux doigts d'exploser mon ordi contre le mur
